How to Sharpen a Dull Chisel
Выберете то, что вам нужно
  1. How to Sharpen a Dull Chisel, How to Sharpen a Dull Chisel: шаг 1, изображение 1 из 1
    • Use water or a mild cleaning solution with a rag or sponge to remove any grime or dirt from the chisel.
    • This helps expose any rust or damage and prevents debris from interfering with sharpening later.
  2. How to Sharpen a Dull Chisel: шаг 2, изображение 1 из 1
    • Next apply WD40 lubricant around any rusted areas before moving on to the next step.
    • Scraping dry rust can damage the metal and make the process unnecessarily difficult.
  3. How to Sharpen a Dull Chisel: шаг 3, изображение 1 из 1
    • Use a brass wire brush to scrub the rusted areas.
    • Focus especially on the blade and any areas that will contact the sharpening stone.
    • Use caution with the wire brush, as its sharp bristles can cause injury.
  4. How to Sharpen a Dull Chisel: шаг 4, изображение 1 из 1
    • Use a clean rag to remove any leftover WD-40 or rust residue.
    • This is important — if oil stays on the blade, it can make your sharpening stone less effective by repelling water.
  5. How to Sharpen a Dull Chisel: шаг 5, изображение 1 из 2 How to Sharpen a Dull Chisel: шаг 5, изображение 2 из 2
    • Soak the wet sharpening stone with water for a couple of minutes and place it on a flat surface.
    • Hold the chisel at a 20-degree angle and push it forward against the stone to grind the edge. After each stroke, lift the chisel and return it to the starting position.
    • Repeat this motion on both sides of the stone until the chisel reaches your desired sharpness.
    • Water acts as a lubricant, helping to carry away metal particles and prevent clogging during sharpening.
  6. How to Sharpen a Dull Chisel: шаг 6, изображение 1 из 2 How to Sharpen a Dull Chisel: шаг 6, изображение 2 из 2
    • With a rag, carefully wipe of any debris and metal shaving possible left on the chisel.
    • Apply a small amount of WD-40 to protect the metal from rust.
    • Keep in mind that this is only a temporary measure.
    • Use caution—this blade is now significantly sharper.
Заключение
After you follow all these steps, you should have a nice, clean chisel
Еще один человек закончил это руководство.
Christine Vu
Участник с: 03/04/25
142 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 3-10, Grodsky Spring 2025 Участник CSU Los Angeles, Team 3-10, Grodsky Spring 2025
CSULA-GRODSKY-S25S3G10
2 членов
Автор 2 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 130
