Введение
In the guide below, you will learn how to shorten a sweatshirt while maintaining the integrity of the original hem. This is a great simple solution for a sweatshirt that is too long for everyday wear.
Выберете то, что вам нужно
Lay your crewneck on a flat surface.
Find your new desired length and mark it with chalk.
Using your chalk mark, use a ruler to mark across the width of your crewneck.
Pin both pieces together with all pins facing perpendicularly to the lines you marked.
Финишная прямая
