How to Shorten the Drawstring on BJJ Gi Pants
Выберете то, что вам нужно
  1. How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: шаг 1, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: шаг 1, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: шаг 1, изображение 3 из 3
    • Put on your Gi pants and adjust the drawstring to the desired tightness.
    • Pull both ends of the drawstring in opposite directions so that they are in front of the pants. Ensure both ends are of nearly equal length, then tie a knot in the center.
    • Use a pen to mark the point where you want the drawstring to end on both sides.
    • Leave at least 2 inches from where the knot ends to ensure you have enough length for tying.
  2. How to Shorten the Drawstring on BJJ Gi Pants: шаг 2, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 2, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 2, изображение 3 из 3
    • Pull one end of the drawstring while holding the waistline of the pants firmly.
    • Continue pulling until the drawstring is entirely out of the waistband.
  3. How to Shorten the Drawstring on BJJ Gi Pants: шаг 3, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 3, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 3, изображение 3 из 3
    • Hold the drawstring steady at the marked points.
    • Use sharp scissors to cut the drawstring at the marked ends, one side at a time.
    • The drawstring material is tough and durable; it's better to cut one end at a time for better control and precision.
  4. How to Shorten the Drawstring on BJJ Gi Pants: шаг 4, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 4, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 4, изображение 3 из 3
    • Hold the lighter close to the end of the drawstring until it starts to melt slightly.
    • Once the end of the drawstring is melted, let it cool down and harden. This will seal the ends and prevent fraying.
    • Repeat the process for the other end of the drawstring.
    • Be very careful when using the lighter to avoid burns or excessive melting. To achieve sealing without burning, only hold the flame to the drawstring for a short time.
  5. How to Shorten the Drawstring on BJJ Gi Pants: шаг 5, изображение 1 из 2 How to Shorten the Drawstring on BJJ Gi Pants: шаг 5, изображение 2 из 2
    • Attach a safety pin to one end of the drawstring.
  6. How to Shorten the Drawstring on BJJ Gi Pants: шаг 6, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 6, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 6, изображение 3 из 3
    • Insert the end of the drawstring with the safety pin into the waistband of the pants.
    • Guide the safety pin through the waistband, working it through the front and back of the pants until it comes out on the other side.
    • Thread the drawstring evenly to avoid bunching and ensure it is distributed evenly throughout the waistband.
  7. How to Shorten the Drawstring on BJJ Gi Pants: шаг 7, изображение 1 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 7, изображение 2 из 3 How to Shorten the Drawstring on BJJ Gi Pants: шаг 7, изображение 3 из 3
    • Pull the drawstrings on both sides to ensure they are of equal length, as shown in the photo.
    • Tie a knot in the center of the pants, adjusting it to a comfortable tightness.
    • Check if the desired length for training is achieved. If not, adjust as necessary.
Заключение
Ensure that the specified length is reached. If not, repeat the process.
Seyedehzahra Ghavamitoranji
Участник с: 07/06/24
145 Репутация
1 руководство автора
Команда
York University, Team N-90, O'Regan Summer 2024 Участник York University, Team N-90, O'Regan Summer 2024
YORK-O'REGAN-SU24SNG90
1 член
Автор 1 руководств
1 Комментарий к руководству
Thanks for including the safety pin trick to put the draw string back into the waistband. I had no idea how to approach that problem until now! The photos are great too.
vvaylon_k - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 31
За всё время: 354
