How to Shorten the Length of Pyjama Pants
Выберете то, что вам нужно
  1. How to Shorten the Length of Pyjama Pants, How to Shorten the Length of Pyjama Pants: шаг 1, изображение 1 из 1
    • Press the pyjamas with an iron to ensure there are no creases.
    • Be careful while using the iron to avoid any burns.
  2. How to Shorten the Length of Pyjama Pants: шаг 2, изображение 1 из 1
    • Take some fabric chalk and measuring tape, then measure the desired length and then make marks on each leg as follows:
    • The left line indicates the desired length line.
    • The right line indicates the one inch line for the new hem you'll be creating.
  3. How to Shorten the Length of Pyjama Pants: шаг 3, изображение 1 из 1
    • Use scissors to remove fabric below the lower one inch line created from the chalk marks to shorten the length. Do this for each pant leg.
  4. How to Shorten the Length of Pyjama Pants: шаг 4, изображение 1 из 3 How to Shorten the Length of Pyjama Pants: шаг 4, изображение 2 из 3 How to Shorten the Length of Pyjama Pants: шаг 4, изображение 3 из 3
    • Take a needle and about 30 inches of thread and put the thread through the needle, then immediately tie the thread off.
    • Be careful with the needle as minor injury may occur if not handled carefully.
  5. How to Shorten the Length of Pyjama Pants: шаг 5, изображение 1 из 3 How to Shorten the Length of Pyjama Pants: шаг 5, изображение 2 из 3 How to Shorten the Length of Pyjama Pants: шаг 5, изображение 3 из 3
    • Fold the pyjama from the one inch extra line so the desired length is achieved, and then hem with the needle.
    • The needle needs to pass through both layers of the folded fabric to start the hemming process.
    • Do this for each pyjama leg.
    • There should be at least 45 stitches on each pyjama leg.
  6. How to Shorten the Length of Pyjama Pants: шаг 6, изображение 1 из 3 How to Shorten the Length of Pyjama Pants: шаг 6, изображение 2 из 3 How to Shorten the Length of Pyjama Pants: шаг 6, изображение 3 из 3
    • At the end of the hem, take the needle through the thread three times to secure the stitch.
Заключение
Congratulations; you did it!
3 участников успешно повторили данное руководство.
Aisha Freed
Участник с: 07/03/22
211 Репутация
1 руководство автора
Команда
York University, Team M-8, Allen Summer 2022 Участник York University, Team M-8, Allen Summer 2022
YORK-ALLEN-SU22SMG8
1 член
Автор 1 руководств
Один комментарий
It is a great and clear repair guide! You shot good photos for every step. Your actions were all well-captured in the photos by using the flip-book style. Properly use of markup also made the guide easier to understand. Also, all the instructions described the actions clearly so it is easy to follow.
Great work!
Cheuk Wai Chan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 100
За всё время: 2,791
