How to Solder Components onto the Beats Pill 1.0
Выберете то, что вам нужно
    1. How to Solder Components onto the Beats Pill 1.0, How to Solder Components onto the Beats Pill 1.0: шаг 1, изображение 1 из 1
      • Plug in the soldering iron and let it reach optimum temperature.
      • The soldering iron is very hot. Please do not touch the the tip of the iron when it is plugged in or until the iron cools.
      • Make sure it is plugged into a 150W outlet (common household wall outlet). Check the device for damages and impurities on the tip such as plastic or grease. Please make sure the iron is not in any contact with potentially flammable items and clean the tip if the soldering iron has been heavily used.
      Спросите у FixBot
      Добавить комментарий
    2. How to Solder Components onto the Beats Pill 1.0: шаг 2, изображение 1 из 1
      • Check that the connection between the wire and the device has good contact. Prior to beginning the soldering process make sure the the conjoining connections between the wire and the device are properly wound together.
      Спросите у FixBot
    3. How to Solder Components onto the Beats Pill 1.0: шаг 3, изображение 1 из 1
      • Apply solder agent to iron until the tip of the iron is coated in the metallic agent. This agent needs to be heated to just under 400 Celsius. Use precaution not to drop hot soldering on you.
      Спросите у FixBot
    4. How to Solder Components onto the Beats Pill 1.0: шаг 4, изображение 1 из 1
      • Touch the soldering iron to the connection and evenly apply a layer of solder to connect and create a good a connection between the wire and the device.
      Спросите у FixBot
    5. How to Solder Components onto the Beats Pill 1.0: шаг 5, изображение 1 из 1
      • Finally wait until the solder cools before re-assembly. It should cool within seconds of application.
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Paul Haas
Участник с: 01/13/15
790 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 3-2, Hickman Winter 2015 Участник USF Tampa, Team 3-2, Hickman Winter 2015
USFT-HICKMAN-W15S3G2
4 членов
Автор 36 руководств
1 Комментарий к руководству
As a developer with Google's platform to enhance the Google Assistant A.I. with better commands, your website recognized my online profile and asked if I would provide better pictures for just soldering process and I would be honored as I'm currently performing this repair now, stay tuned!
Jamie J. - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 38
За всё время: 6,143
