How to Start Up a Mac in Internet Recovery Mode
  1. How to Start Up a Mac in Internet Recovery Mode, How to Start Up a Mac in Internet Recovery Mode: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • If you're installing MacOS to a new drive with Internet Recovery, you can skip this step.
    Спросите у FixBot
    Добавить комментарий
  2. How to Start Up a Mac in Internet Recovery Mode: шаг 2, изображение 1 из 1
    • Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
    Спросите у FixBot
  3. How to Start Up a Mac in Internet Recovery Mode: шаг 3, изображение 1 из 2 How to Start Up a Mac in Internet Recovery Mode: шаг 3, изображение 2 из 2
    • When the spinning globe animation appears, you can release the keys.
    • The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
    Спросите у FixBot
  4. How to Start Up a Mac in Internet Recovery Mode: шаг 4, изображение 1 из 1
    • Once a network connection has been established, a progress bar will appear underneath the spinning globe.
    • This process is prone to timing out. If you receive an error, try again using a cable connection to reach the internet rather than WiFi. Depending on your model, you may need an adapter to accomplish this.
    Спросите у FixBot
  5. How to Start Up a Mac in Internet Recovery Mode: шаг 5, изображение 1 из 1
    • When Internet Recovery has loaded, you will see the macOS recovery screen.
    Спросите у FixBot
Заключение
From the recovery menus, you can restore your data from a Time Machine backup, Reinstall macOS, get help online, and use Disk Utility to format and diagnose problems with any connected storage drives.
85 человек успешно провели ремонт по этому руководству.
Taylor Dixon
Участник с: 06/26/18
72 633 Репутация
Автор 94 руководств
44 Комментарии к руководству
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - Ответить Поделиться
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon - Ответить Поделиться
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - Ответить Поделиться
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - Ответить Поделиться
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
Orlando Gomez - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 39
За последние 7 дней: 319
За последние 30 дней: 1,526
За всё время: 565,374
