Введение
Active End: The end of the tie that will be used to tie the knot. This can be either the wide end or narrow end of the tie depending on the tie knot.
Shirt Collar: A band of material around the neck of a shirt that can either be folded or unfolded.
Neck Loop: The loop of the tie that goes around the collar.
Keeper Loop: A piece of fabric that is sewn onto the underside of the wide end of the tie that can be used to keep the narrow end of the tie hidden.
Four-in-Hand: A simple and common knot that is incredibly versatile and appropriate for many different occasions.
Выберете то, что вам нужно
Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
The wide end of the tie will be your active end.
Take the active end and cross it over the narrow end, so that it points to the left.
Pull the active end down through the wrap you created in step 5 (see second picture).
Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
Tuck the narrow end of the tie through the keeper loop.
Fold your collar down when the knot is finished.
Congratulations! You've successful tied the Four-in-Hand knot!
5 участников успешно повторили данное руководство.
