How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
Выберете то, что вам нужно
  1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 1, изображение 1 из 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 1, изображение 2 из 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 1, изображение 3 из 3
    • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
    • Loosening the fasteners will help to loosen the barrel in Step 2.
  2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 2, изображение 1 из 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 2, изображение 2 из 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 2, изображение 3 из 3
    • Twist in the clockwise direction to tighten the barrel adjusters.
  3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 3, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 3, изображение 2 из 2
    • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
    • It should be about an inch if properly tightened.
    • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
  4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 4, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 4, изображение 2 из 2
    • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
    • Start by squeezing the brake arms together as much as possible.
  5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 5, изображение 1 из 1
    • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
    • Loosen the bolt until the cable can be adjusted easily by hand.
  6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 6, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 6, изображение 2 из 2
    • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
    • Stop pulling when the brake pads are one or two millimeters away from the wheel.
  7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 7, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 7, изображение 2 из 2
    • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
  8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 8, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 8, изображение 2 из 2
    • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
    • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
  9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 9, изображение 1 из 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: шаг 9, изображение 2 из 2
    • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
Заключение
Еще один человек закончил это руководство.
Emily Arana
Участник с: 04/19/23
169 Репутация
1 руководство автора
Команда
UCD-MORRIS-S23S1G1 Участник UCD-MORRIS-S23S1G1
Community
3 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 163
