How to Troubleshoot Generic 1A USB Car Charger
Выберете то, что вам нужно
  1. How to Troubleshoot Generic 1A USB Car Charger, How to Troubleshoot Generic 1A USB Car Charger: шаг 1, изображение 1 из 1
    • Insert the USB Micro end into the breakout, and insert the adapter into a power source, set for 12V (or automatic if in vehicle).
    • Caution: Since your device is connected to a power source, there is a low voltage current going through that could damage components.
  2. How to Troubleshoot Generic 1A USB Car Charger: шаг 2, изображение 1 из 3 How to Troubleshoot Generic 1A USB Car Charger: шаг 2, изображение 2 из 3 How to Troubleshoot Generic 1A USB Car Charger: шаг 2, изображение 3 из 3
    • Set the multimeter to VDC, and place the leads as shown.
    • The voltage should be about 5V.
    • If the voltage is lower, check the output of the power supply. If the power supply voltage is above 6V, then we will need to continue to Step 4.
  3. How to Troubleshoot Generic 1A USB Car Charger: шаг 3, изображение 1 из 3 How to Troubleshoot Generic 1A USB Car Charger: шаг 3, изображение 2 из 3 How to Troubleshoot Generic 1A USB Car Charger: шаг 3, изображение 3 из 3
    • Unscrew the tip to uncover the fuse.
    • Remove the fuse from the charger.
    • Make sure to document the order that everything is unscrewed. This will be important for reassembly.
  4. How to Troubleshoot Generic 1A USB Car Charger: шаг 4, изображение 1 из 2 How to Troubleshoot Generic 1A USB Car Charger: шаг 4, изображение 2 из 2
    • Set the multimeter to test continuity.
    • Test to know how your meter reads a closed circuit.
    • Test the fuse with the multimeter.
    • If your fuse does not allow a current to flow, you will need to replace it.
  5. How to Troubleshoot Generic 1A USB Car Charger: шаг 5, изображение 1 из 2 How to Troubleshoot Generic 1A USB Car Charger: шаг 5, изображение 2 из 2
    • If the fuse is allowing a current to flow, you may move on, opening the body of the charger.
    • Be aware, there may be small springs inside body.
    • Look for small breaks in the small wires. Repair of these types of problems are outside the scope of this iFixit guide, but other guides may help.
Заключение
2 участников успешно повторили данное руководство.
Jay R Fude
Участник с: 10/10/18
299 Репутация
1 руководство автора
Команда
Missouri Western, Team S1-G2, Cools Stephens Fall 2018 Участник Missouri Western, Team S1-G2, Cools Stephens Fall 2018
MWSU-COOLS STEPHENS-F18S1G2
2 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 17
За всё время: 1,526
