Введение
Over half a million Americans rely on a feeding tube for proper nutrition, myself included. Although these are lifesaving tools, they are not infallible. Often, they become clogged even with proper maintenance. This guide will provide home solutions on how to fix a clogged tube, hopefully saving one's self an arduous trip to the hospital.
Запчасти
Детали не указаны.
  1. Test your tube. Use a 35ml plunger to test your tube, just to confirm it is clogged.
    • Test your tube. Use a 35ml plunger to test your tube, just to confirm it is clogged.
    • Exert a decent amount of force.
  2. Massage the tube. Roll the tubing in between your fingers and “massage” it.
    • Massage the tube. Roll the tubing in between your fingers and “massage” it.
    • The clog may be in the external tubing and doing so may break it up.
  3. Switch to a smaller plunger. Start using a 10ml plunger.
    • Switch to a smaller plunger. Start using a 10ml plunger.
    • The smaller the plunger, the more pressure is exerted.
  4. Flush hot water. Fill your 10ml plunger (and extension tubing, if applicable) with hot water. As hot as you can safely tolerate. Use this to flush your tube.
    • Flush hot water. Fill your 10ml plunger (and extension tubing, if applicable) with hot water. As hot as you can safely tolerate. Use this to flush your tube.
  5. Pulsate. Pulsate the 10ml plunger back and forth, in quick motion. This helps to dismantle the clog.
    • Pulsate. Pulsate the 10ml plunger back and forth, in quick motion. This helps to dismantle the clog.
  6. Flush a combination of hot water and meat tenderizer. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with a combination of hot water and meat tenderizer.
    • Flush a combination of hot water and meat tenderizer. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with a combination of hot water and meat tenderizer.
    • The tenderizer is known to break up clogs.
  7. Pulsate. Pulsate the 10ml plunger once again, in a quick motion.
    • Pulsate. Pulsate the 10ml plunger once again, in a quick motion.
  8. Flush Coca-Cola. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with Coca-Cola. Flush your tube.
    • Flush Coca-Cola. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with Coca-Cola. Flush your tube.
    • Regular coke is the best for breaking up clogs due to its carbonation levels.
  9. Pulsate, then let Coca-Cola sit. Pulsate the 10ml plunger once again, in a quick motion. If the clog persists, allow the Coke to sit in your tube.
    • Pulsate, then let Coca-Cola sit. Pulsate the 10ml plunger once again, in a quick motion. If the clog persists, allow the Coke to sit in your tube.
    • You may leave the Coke in your tube for up to one hour.
  10. Test your feeding tube. It should flush easily.
    • Test your feeding tube. It should flush easily.
Заключение
The hope is to successfully unclog the feeding tube at home. Of course, always contact your health care physician in times of concern.
Еще один человек закончил это руководство.
Jaquie Beckwith
Участник с: 23.01.2018
211 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Участник USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 61
За последние 30 дней: 263
За всё время: 8,465
