How to Unclog a Keurig BVMC-KG5
Выберете то, что вам нужно
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: шаг 1, изображение 1 из 1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: шаг 2, изображение 1 из 1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: шаг 3, изображение 1 из 3 How to Unclog a Keurig BVMC-KG5: шаг 3, изображение 2 из 3 How to Unclog a Keurig BVMC-KG5: шаг 3, изображение 3 из 3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: шаг 4, изображение 1 из 1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: шаг 5, изображение 1 из 1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Заключение
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
2 участников успешно повторили данное руководство.
Hunter Ashbrook
Участник с: 03/21/16
155 Репутация
1 руководство автора
Команда
Michigan Tech, Team 1-1, Lauer Spring 2016 Участник Michigan Tech, Team 1-1, Lauer Spring 2016
MTU-LAUER-S16S1G1
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 5,670
