Введение
In this guide, I will explain how to remove buildup in the shower drain.
Выберете то, что вам нужно
Begin by putting on a pair of disposable gloves to protect your hands from what is inside your drain and from the chemicals in drain opener.
Remove the stopper from your shower drain, if possible.
Follow this link to determine how to remove the specific kind of drain stopper you have.
Once the drain stopper is out of the way, use your fingers, tweezers, or almost any long thin object to pull out hair and larger items clogging the drain.
Dispose of anything you were able to remove from your drain.
If you cannot remove your drain stopper, skip ahead until step 7.
Cover the drain with a plunger and run the water in your bathtub or shower until it covers at least half of the plunger.
Without breaking the seal of the plunger on the drain, push the plunger sharply down and up a few times.
Push down on the plunger again, but pull up sharply to break the seal.
This will hopefully dislodge what is clogging the drain. Any residual items may be removed as in step 3.
The drain opener you purchased should have instructions on the back which will tell you how much of the drain cleaner to use.
Slowly pour the liquid drain opener down the drain, but avoid pouring the liquid on your shower floor and drain stopper.
If you were unable to remove the drain stopper, lift the stopper up as much as possible and follow the steps above.
Wait at least the time stated on your bottle of drain opener.
Different drain openers have different wait times, ranging from 10 minutes to 10 hours.
After an appropriate amount of time, run hot water down the drain to flush out any remaining blockage.
To reassemble your drain stopper, follow the steps you took in step one in reverse order.
2 участников успешно повторили данное руководство.
