Введение
This shows how to update the display drivers for your Dell laptop.
  1. To start you will want to hit the Windows key and the R key at the same time to pull up the Run Window.
    • To start you will want to hit the Windows key and the R key at the same time to pull up the Run Window.
  2. In the run window type "devmgmt.msc", and hit the OK button.
    • In the run window type "devmgmt.msc", and hit the OK button.
  3. The device manager window will look like this. The items inside of the list may be a bit different on your computer. Find the item called "Display Adapters" and click on the arrow to the left of it that is shaped like this: >
    • The device manager window will look like this. The items inside of the list may be a bit different on your computer. Find the item called "Display Adapters" and click on the arrow to the left of it that is shaped like this: >
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. The name of the display adapter may be different from the one on my computer.  For this step we want the item that is in the spot that I have highlighted blue in the picture. Right click on it, and from the menu that appears click on the option that says "Update Driver". It should be the top option on the list.
    • The name of the display adapter may be different from the one on my computer. For this step we want the item that is in the spot that I have highlighted blue in the picture. Right click on it, and from the menu that appears click on the option that says "Update Driver". It should be the top option on the list.
  6. You should see a window that looks like this pop up. Click on the option that says "Browse my computer for driver software".
    • You should see a window that looks like this pop up. Click on the option that says "Browse my computer for driver software".
  7. The next step will look like this.  Click on the option near the bottom that says "Let me pick from a list of available drivers on my computer"
    • The next step will look like this. Click on the option near the bottom that says "Let me pick from a list of available drivers on my computer"
  8. The names of the items in this list may be different for your computer. If you have one named "Microsoft Basic Display Adapter" then select that one and hit next. If that one is not in the list then pick the one with the oldest date in the name.
    • The names of the items in this list may be different for your computer. If you have one named "Microsoft Basic Display Adapter" then select that one and hit next. If that one is not in the list then pick the one with the oldest date in the name.
    • Once you follow the instructions on the next step your computer's screen may go black for a moment. This is normal part of the update process, and nothing to worry about.
  9. Once it is done updating you should see this screen, and the software will be up to date and you should not see the colored and white lines on your computer screen anymore.
    • Once it is done updating you should see this screen, and the software will be up to date and you should not see the colored and white lines on your computer screen anymore.
Финишная черта
3 участников успешно повторили данное руководство.
Joshua Matzke
Участник с: 27.07.2016
254 Reputation
1 Guide authored
2 Comments
You can refresh your driver by going on Dell official site or you can likewise introduce a bland designs driver from your illustrations card maker's site. For more data about it, simply click here: Dell Customer Support
Compaq Support Number - Ответить
If this method is not working you can do go to Dell customer support and you can talk to him . You also download drivers manually step by step
step 1: Open Google Search
step 2: Search Dell Laptop Display Driver
step 3: Open site enter model model number
step 4: Download you display driver by choose suitable options
step 5": and Download it Simple
edna taylor - Ответить
Past 24 Hours: 1
Past 7 Days: 33
Past 30 Days: 164
All Time: 3,747
