Введение
Sweaters must be hand-washed to prevent warping. Fortunately, hand-washing is easy. Follow these easy steps to a clean sweater. If you have a stain, check out our spot-washing guide.
We recommend a detergent with as few chemicals as possible, such as Seventh Generation, which is linked in the tools section of this guide.
Выберете то, что вам нужно
Fill the sink with cool water.
Add some gentle liquid detergent to the water.
Submerge the sweater in the soapy water.
Gently press down to make sure that the entire sweater is in the water.
Allow the sweater to soak for 15-20 minutes.
Drain the sink and rinse the sweater, squeezing it gently in your hands to release all the extra soap and water.
Place a towel on a waterproof surface.
Lay the sweater out on the towel.
Gently lay the sweater flat, lightly stretching it to its proper size.
Lay the sleeves out flat, gently stretching them to their proper size.
Allow the sweater to lay undisturbed until it is dry.
Еще один человек закончил это руководство.
2 Комментариев
It was a very good experience, thank you. <a href="http://playfnfgame.com/">fnf</a>
It was a very good experience, thank you. vex7
