Введение
Contrary to popular belief, washing your jacket doesn't wear it out—in fact, it prolongs the life of your jacket. Washing and drying your down jacket is easy; it just takes a few simple tricks to keep the down nice and fluffy. Follow these steps for a warm, clean jacket on your next adventure.
We recommend you use a down wash that's low in chemicals and as environmentally friendly as possible, such as Granger's (linked in the tools section below).
Выберете то, что вам нужно
Lay your jacket out and zip up all the zippers.
If your jacket has hook-and-loop tape, fasten it closed.
Place the jacket in your washing machine.
Set the load size on the washing machine to small.
Set the water temperature on the washing machine to cold/cold.
Run the washing machine on a gentle or normal wash cycle.
Remove the jacket from the washing machine and place it in the dryer.
Add a couple of tennis balls to the dryer.
Set the dryer on a low-heat setting with a normal dry-cycle time.
Start the dryer.
12 участников успешно повторили данное руководство.
3 Комментариев
Inexpensive and warm down jackets have long since become part of our wardrobe. And almost every jacket has a warning label prohibiting wash and dry it at home.But enterprising housewives long found a way to wash down jackets at home. It turns out that it is not so difficult if you know some tricks. Here you will find tips how to wash down jacket in the washing machine and by hand https://pinkycloud.com/how-to-wash-a-dow....
It is also very important to know how to store down jackets, it very much depends on how long you will wear it http://triplefatgoose.com/blog/how-to-ta... Here are details and even more
