Введение
This is a simple guide to wiring a keystone jack for use in house and business applications.
Выберете то, что вам нужно
Use your wire stripper to cut the outer sheath
Do Not Rotate more than 3-4 times as it will cut the wires underneath.
when the length of exposed wires are at a decent length (a little less than a thumbs length) separate the wires by color.
on the keystone jack you will see colors. line the wires up to the corresponding colors (white blue - blue, white orange - orange, etc.)
use the punchdown tool with the longer side of the blade on the outside to punch the wires in and it will cut off the excess.
repeat for each color
place the jack into the mounting box, there should be places for zip ties to hold the cable in place
place the cover on top and you are done with your cable!
test the line using a cable tester.
Make Sure to test with a cable tester
6 человек успешно провели ремонт по этому руководству.
