How to access a Nikon Coolpix S210 jammed lens
Выберете то, что вам нужно
  1. How to access a Nikon Coolpix S210 jammed lens, Battery: шаг 1, изображение 1 из 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. How to access a Nikon Coolpix S210 jammed lens: шаг 2, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 2, изображение 2 из 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. How to access a Nikon Coolpix S210 jammed lens, Back Case: шаг 3, изображение 1 из 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. How to access a Nikon Coolpix S210 jammed lens: шаг 4, изображение 1 из 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. How to access a Nikon Coolpix S210 jammed lens: шаг 5, изображение 1 из 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. How to access a Nikon Coolpix S210 jammed lens: шаг 6, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 6, изображение 2 из 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. How to access a Nikon Coolpix S210 jammed lens, LCD screen: шаг 7, изображение 1 из 3 How to access a Nikon Coolpix S210 jammed lens, LCD screen: шаг 7, изображение 2 из 3 How to access a Nikon Coolpix S210 jammed lens, LCD screen: шаг 7, изображение 3 из 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. How to access a Nikon Coolpix S210 jammed lens: шаг 8, изображение 1 из 1
    • Gently remove the LCD screen.
  9. How to access a Nikon Coolpix S210 jammed lens, Circuit Board Cover: шаг 9, изображение 1 из 1
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  10. How to access a Nikon Coolpix S210 jammed lens: шаг 10, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 10, изображение 2 из 2
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
  11. How to access a Nikon Coolpix S210 jammed lens, How to access a Nikon Coolpix S210 jammed lens: шаг 11, изображение 1 из 1
    • Remove the two silver 3.1mm screws from the silver plate.
  12. How to access a Nikon Coolpix S210 jammed lens: шаг 12, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 12, изображение 2 из 2
    • There is a ribbon to the bottom left of the silver plate. It is being held in place by a black latch.
    • Pry the spudger under the black latch and lift gently. The ribbon will release easily.
    • There is a loop of tape to the bottom right of the silver plate.
    • Slide the tip of the spudger inside the loop of tape and pry upward while removing the yellow plate with your other hand.
  13. How to access a Nikon Coolpix S210 jammed lens: шаг 13, изображение 1 из 1
    • Remove all six 3.5mm screws from the silver plate.
    • Lift up on the silver plate to remove.
    • Note: When reassembling, pay careful attention to the circled screw locations.
  14. How to access a Nikon Coolpix S210 jammed lens: шаг 14, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 14, изображение 2 из 2
    • Using tweezers, remove the cylindrical gear from the camera.
  15. How to access a Nikon Coolpix S210 jammed lens: шаг 15, изображение 1 из 2 How to access a Nikon Coolpix S210 jammed lens: шаг 15, изображение 2 из 2
    • Place the spudger on the outermost surface of the lens and push in. This will extend your camera lens.
Заключение
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different screws.
8 участников успешно повторили данное руководство.
Mallory Arend
Участник с: 01/17/11
444 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-17, Amido Winter 2011 Участник Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 членов
Автор 12 руководств
9 Комментариев
i read all info but too scared to try it . is there a camera repair store near mt. home ar. ? thank you
oaklandfishing - Ответить
wd 40 helps
spray it on the jamed lens
and it will open and close
aurelianporumb -
I forgot my login information on the old account used to write the guide but:
Do NOT use wd 40 on the jammed lens cap. Getting any of it on the lens itself can severely harm the optics and essentially ruin the camera.
John -
What do you do when you push the lens out?
Kaseson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 81
За всё время: 35,006
