Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the two wrenches to loosen the nut that holds the brake cable to the braking mechanism. Grip the nut with one wrench, then grip the bolt (on the other side) with the second wrench.
You might want to enlist a friend to hold on to the end of the cable for you so it doesn't fall off when you loosen the nut that holds it down.
Now that the nut is loosened, pull the cable tighter or looser to adjust the resting state of the brake clamp.
Adjust the tension so that the brake pads are about 1 to 2 mm from the rim of the wheel.
Afterwards, you can fine-tune the adjustment by tightening or loosening the barrel adjuster located about 7 inches above the brake levers.
