How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: шаг 1, изображение 1 из 2 How to adjust Razor A steering column, How to adjust Razor A steering column: шаг 1, изображение 2 из 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: шаг 2, изображение 1 из 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Финишная прямая
4 человек успешно провели ремонт по этому руководству.
Jordyn
Участник с: 10/09/12
565 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 9-13, Amido Fall 2012 Участник Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 членов
Автор 10 руководств
8 Комментарии к руководству
what move it with your hands? - didn't help
Heather McCasland - Ответить
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Ответить
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Ответить
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 21
За последние 30 дней: 86
За всё время: 43,240
