Выберете то, что вам нужно
Install 4 x M2.5 bolts through the baseplate to hanger hub.
Cut the motor axle to the 18mm length from the baseplate.
Attach stainless steel plate to the motor
Apply retaining compound like (Loctite 648) to keyway and install in the keyway
Tighten M2 grub screws on motor gear to secure motor gear on axle.
Mount assembly to hanger
Tighten grub screws to lock assembly in place.
Add brass washer to axle before mounting wheel hub.
Attach wheel hub assembly to axle
Attach wheel to the wheel gear assembly
Loosen up motor bolts so that motor gear would press wheel gear.
Use sheet of paper to drive it through wheel gear and motor gear. Spin wheel to push paper through the gears
After meshing is good tighten motor bolts
Remove wheel from wheel gear assembly
Put wheel gear into the cover and attach V-ring on the wheel gear.
It is good time to apply grease to the gears
Use 7xM2 bolts to attach motor cover to baseplate
Do a test spin on the bench to make sure everything is fine and sounds okay
On the first test ride start by slowly accelerating and slowly braking to make sure everything is working fine.
If there is some minor vibration happening at specific RPM it can be some misbalance in wheel/gears which should disappear after gears sit down in their place.
