How to check Black and Decker 3-Cup Rice Cooker continuity
Выберете то, что вам нужно
  1. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Lid and Bowl: шаг 1, изображение 1 из 1
    • Make sure the device is unplugged before beginning disassembly!
    • Lift the lid and bowl from the top of the device.
  2. How to check Black and Decker 3-Cup Rice Cooker continuity, Turn the Device Upside-Down: шаг 2, изображение 1 из 1
    • Turn the device upside-down, so that the four legs of the device point upwards.
  3. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Rubber Cushions: шаг 3, изображение 1 из 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Rubber Cushions: шаг 3, изображение 2 из 2
    • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  4. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Spanning Screw: шаг 4, изображение 1 из 1
    • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  5. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Leg Screws: шаг 5, изображение 1 из 1
    • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
    • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
  6. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Brass Plate: шаг 6, изображение 1 из 1
    • Lift the brass plate off the device and set it aside.
  7. How to check Black and Decker 3-Cup Rice Cooker continuity, Color the Wires: шаг 7, изображение 1 из 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Color the Wires: шаг 7, изображение 2 из 2
    • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
    • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
    • Unscrew the screw at the junction near the opposite side of the device from the front panel.
    • Label each of the two wires at this junction with a single color of tape.
  8. How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Second Wire Junction: шаг 8, изображение 1 из 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Second Wire Junction: шаг 8, изображение 2 из 2
    • Unscrew the screw at the junction just clockwise from the button panel.
    • Label the three wires of this junction with tape of a second color.
  9. How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Third Wire Junction: шаг 9, изображение 1 из 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Third Wire Junction: шаг 9, изображение 2 из 2
    • Unscrew the screw from the wire junction just behind the front panel.
    • Label the three wires at this junction with a third color of tape.
  10. How to check Black and Decker 3-Cup Rice Cooker continuity, Plug the Device into an Outlet: шаг 10, изображение 1 из 1
    • During these steps, DO NOT touch the wires directly. You may be electrocuted.
    • Plug the device's power cord into a functioning outlet.
  11. How to check Black and Decker 3-Cup Rice Cooker continuity, Check the Voltage between the Wires: шаг 11, изображение 1 из 1
    • Locate the two wires which are connected directly to the power cord. Unlike the other wires, they are sheathed in a particularly thick, dot-textured plastic.
    • Make sure the voltmeter is on and set to a setting beween 120 and 500V. For most voltmeters the proper setting for this is the 200V setting.
    • Attach one of the voltmeter's probes to the metal portions of each of the two wires connected to the power cord's end on the device
    • The voltmeter should read a number significantly above 20V. A reading between 100 and 150 V indicates that the device is getting enough power. A lower number indicates the power cord is broken.
Заключение
This guide alters no parts of the device, so no reassembly is needed from these steps.
Lillian Heng
Участник с: 09/26/14
709 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 12-1, Forte Fall 2014 Участник Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 1,500
