How to check Fujifilm FinePix S8200 for loose LCD connection
Выберете то, что вам нужно
  1. How to check Fujifilm FinePix S8200 for loose LCD connection, Batteries: шаг 1, изображение 1 из 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 2, изображение 1 из 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 3, изображение 1 из 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: шаг 4, изображение 1 из 3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: шаг 4, изображение 2 из 3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: шаг 4, изображение 3 из 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 5, изображение 1 из 3 How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 5, изображение 2 из 3 How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 5, изображение 3 из 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 6, изображение 1 из 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. How to check Fujifilm FinePix S8200 for loose LCD connection, How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 7, изображение 1 из 1
    • Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
  8. How to check Fujifilm FinePix S8200 for loose LCD connection: шаг 8, изображение 1 из 1
    • Fold the LCD screen back into the proper position.
Заключение
Joseph Kelley
Участник с: 01/15/15
228 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 7-1, Remmell Winter 2015 Участник USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 689
