Запчасти
Никакие детали не требуются.
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  4. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  8. Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  9. Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
    • Remove the three screws holding in the DVD tray
  10. Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  11. Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
    • Gently lift the DVD tray off of the motherboard.
  12. Use the tweezers to make sure all the buttons aren't stuck.
    • Use the tweezers to make sure all the buttons aren't stuck.
Заключение
2 участников успешно повторили данное руководство.
Mitchell Hart
Участник с: 21.01.2011
834 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 3-30, Regan Winter 2011 Member of Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,252
