Введение
This guide will teach you how to clean your EarPods
Инструменты
Запчасти
Детали не указаны.
  1. If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
    • If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
  2. Use a toothpick to rub all the holes in the earphone Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
    • Use a toothpick to rub all the holes in the earphone
    • Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
  3. Repeat the process for the other EarPod Repeat the process for the other EarPod
    • Repeat the process for the other EarPod
  4. Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod Ignore the fact that the alcohol is in the Earpods' case
    • Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod
    • Ignore the fact that the alcohol is in the Earpods' case
  5. Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker. Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
    • Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
  6. Let the EarPods dry for at least 10 minutes before using
    • Let the EarPods dry for at least 10 minutes before using
    • Let the Earpods dry by itself, if you use a fan, a hair dryer, or anything else, you could generate corrosion inside and that will ruin it
Заключение
Remember to dry your Earpods for 10 minutes.
80 участников успешно повторили данное руководство.
jimenezser
Участник с: 29.08.2012
3 704 Репутация
Автор 4 руководств
Комментариев: 30
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - Ответить
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - Ответить
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 53
За последние 7 дней: 330
За последние 30 дней: 1,400
За всё время: 375,299
