How to clean Apple Mighty Mouse scroll ball
Выберете то, что вам нужно
  1. How to clean Apple Mighty Mouse scroll ball, How to clean Apple Mighty Mouse scroll ball: шаг 1, изображение 1 из 1
    • Before you continue, turn off the mouse using the slide switch underneath the mouse.
    • Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
    • You can also try blowing into the "ball hole" with a can of compressed air.
Заключение
Allow the mouse to dry for a few minutes before turning it back on to test it.
52 человек успешно провели ремонт по этому руководству.
bushing
Участник с: 04/23/10
10 363 Репутация
Автор 13 руководств
15 Комментариев
In order to clean perfectly the scrollball, you can hold the mouse upside down, and roll very quickly the scrollball on a white A4 papersheet (As if you wanted to colour the papersheet with the scrollball). Normally, you'll see some grey stripe of dust on the paper sheet!
Ludal - Ответить
Wow - Ludal's advice actually worked! I'm amazed. Paper -- just a plain sheet of paper.
Marvin Miller -
I can't believe I just found this post in 2015, gotta say thank you for saving $53 bucks!
Junior Harrison -
I actually did both things but I used one of those wipes for eyeglasses which have alcohol in them after rubbing it on paper. Worked great.
Brian Kemian -
Thanks a loit. Even in 2020 it helped ;-)
Robert Reichel -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 31
За последние 30 дней: 116
За всё время: 45,035
