How to clean Canon PowerShot A550 buttons
Выберете то, что вам нужно
  1. How to clean Canon PowerShot A550 buttons, Front and Back Covers: шаг 1, изображение 1 из 3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: шаг 1, изображение 2 из 3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: шаг 1, изображение 3 из 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. How to clean Canon PowerShot A550 buttons: шаг 2, изображение 1 из 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. How to clean Canon PowerShot A550 buttons: шаг 3, изображение 1 из 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. How to clean Canon PowerShot A550 buttons: шаг 4, изображение 1 из 2 How to clean Canon PowerShot A550 buttons: шаг 4, изображение 2 из 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. How to clean Canon PowerShot A550 buttons: шаг 5, изображение 1 из 1
    • The camera should look like this once the front cover is removed.
  6. How to clean Canon PowerShot A550 buttons: шаг 6, изображение 1 из 3 How to clean Canon PowerShot A550 buttons: шаг 6, изображение 2 из 3 How to clean Canon PowerShot A550 buttons: шаг 6, изображение 3 из 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. How to clean Canon PowerShot A550 buttons: шаг 7, изображение 1 из 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. How to clean Canon PowerShot A550 buttons, How to clean Canon PowerShot A550 buttons: шаг 8, изображение 1 из 1
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
Заключение
2 участников успешно повторили данное руководство.
Shaelyn Thomas
Участник с: 04/19/11
332 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-6, Regan Spring 2011 Участник Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 членов
Автор 22 руководств
Один комментарий
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 13
За всё время: 1,937
