Введение
If your drive is having problems reading or writing a disk, dust may have collected on the lens, which will need to be cleaned.
Выберете то, что вам нужно
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
4 участников успешно повторили данное руководство.
