Инструменты
Запчасти
No parts specified.
Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
Remove the plastic cover by pulling up on the back and away from the faceplate.
Remove the faceplate by unclipping the latches on the bottom of the device.
Once it's unlatched, pull the faceplate off.
Using your philips screwdriver, remove the two screws at the base of the disc drive. (See image)
Remove the two screws on either side of the green circuit-board as seen in the photos. Once the screws are removed, gently lift the board so you can remove the disc drive. BE CAREFUL! The board is still attached to the base of the DVD player. You just need to lift it enough to pull the disc drive out.
You can now gently lift the disc drive out of the the DVD player. BE CAREFUL! The disc drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Turn disc drive over so you can see the gears on the bottom.
Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
2 участников успешно повторили данное руководство.
