Введение
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Выберете то, что вам нужно
In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Your camera should look something like this.
Clean the marked areas with a cotton swab soaked in CLR or vinegar.
Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 участников успешно повторили данное руководство.
2 Комментариев
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
