How to clean Nikon N2000 (F301) battery corrosion
Выберете то, что вам нужно
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. How to clean Nikon N2000 (F301) battery corrosion: шаг 2, изображение 1 из 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. How to clean Nikon N2000 (F301) battery corrosion: шаг 3, изображение 1 из 1
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  3. How to clean Nikon N2000 (F301) battery corrosion: шаг 4, изображение 1 из 1
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  4. How to clean Nikon N2000 (F301) battery corrosion: шаг 5, изображение 1 из 1
    • All cleaned up!
Заключение
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 участников успешно повторили данное руководство.
Zachary Phillips
Участник с: 04/08/11
247 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 25-26, Garner Spring 2011 Участник Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 членов
Автор 12 руководств
2 Комментариев
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Ответить
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
Wolf Naegeli - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 18
За последние 30 дней: 71
За всё время: 15,671
