Введение
With these remotes it seems to be a common problem some buttons cease to work after a couple of years. Usually, you just need to open the remote and clean the circuit board.
Выберете то, что вам нужно
For later testing: X marks butttons which still work, O marks buttons that don't.
Open battery housing and remove the batteries
Remove the screw located in the center of the battery housing
Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
If necessary, add contact spray or alike to the buttom of the rubber buttons
After cleaning and before full re-assembly, you might want to try if things improved.
Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
If the repair worked, you should the red top LED flashing
Put it all back together again. (Don't forget the screw in the battery housing.)
You might need some new batteries as well
23 человек успешно провели ремонт по этому руководству.
29 Комментарии к руководству
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
