Введение
This guide will teach you how to take apart your Vape Mod completely, analyze which parts need to be cleaned, and how to correctly clean them.
Выберете то, что вам нужно
Start by removing the top cap of your Vape Mod.
At the bottom of the tube, unscrew the firing pin.
Take the battery out of the Vape Mod.
Inspect all of the parts that will need to be cleaned:
The firing pin
The RDA threading
The bottom of the inside of the tube
Clean the Firing pin by dipping a paper towel into hot water.
Carefully rotate the hot towel around the middle area, rubbing the grime away.
Get a new paper towel wet with the hot water.
Clean the RDA threading by rotating the wet paper towel back and forth across it.
Twist it until it can easily fit inside of the tube.
Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
Fire your Vape Mod. If the coils are heating up, it has been fixed!
If your Vape Mod is still not firing, consider getting a new build.
13 участников успешно повторили данное руководство.
