How to Clean the Dell MO56UC
Выберете то, что вам нужно
  1. How to Clean the Dell MO56UC, Disassembly: шаг 1, изображение 1 из 2 How to Clean the Dell MO56UC, Disassembly: шаг 1, изображение 2 из 2
    • Unplug the USB cord to disconnect the mouse from the power
    • Use a Phillips 00 Screwdriver to unscrew one screw.
  2. How to Clean the Dell MO56UC, Complete mouse disassembly: шаг 2, изображение 1 из 1
    • Take off the top of the mouse.
    • Use a microfiber cloth or a damp towel to remove any debris located inside of the highlighted areas.
  3. How to Clean the Dell MO56UC, Sensors: шаг 3, изображение 1 из 1
    • Twist the ball counter-clockwise to remove it.
    • Clean the ball with a microfiber cloth.
  4. How to Clean the Dell MO56UC, Wipe gently with microfiber cloth: шаг 4, изображение 1 из 1
    • Clean the vertical and horizontal ball sensors with a microfiber cloth.
  5. How to Clean the Dell MO56UC, Examining Wheel: шаг 5, изображение 1 из 1
    • Examine the wheel for debris. The wheel can get dirty frequently which affects performance and may cause issues.
    • Remove any debris found and clean the wheel with a microfiber cloth.
  6. How to Clean the Dell MO56UC, Sensor Error: шаг 6, изображение 1 из 1
    • The wheel clicker sensor is located under the wheel.
  7. How to Clean the Dell MO56UC, Wheel Clicker: шаг 7, изображение 1 из 1
    • Remove the wheel to expose the sensor.
    • Remove any debris and wipe down the sensor with a microfiber cloth.
  8. How to Clean the Dell MO56UC, Plug it back in: шаг 8, изображение 1 из 1
    • Insert the USB Cable back into your computer to supply with power.
    • Test functions of the mouse to insure proper cleaning and reassembly.
  9. How to Clean the Dell MO56UC, If there are still issues, Examine the cord and the USB leads in the male port: шаг 9, изображение 1 из 1
    • Examine the cord for frays or any exposed wire that may cause a bad connection.
Заключение
4 участников успешно повторили данное руководство.
Adrian Capparelli
Участник с: 10/23/14
180 Репутация
1 руководство автора
Команда
Montana Tech, Team 1-4, Shirk Fall 2014 Участник Montana Tech, Team 1-4, Shirk Fall 2014
MTUM-SHIRK-F14S1G4
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 16
За последние 30 дней: 62
За всё время: 3,403
