How to clean out a Black and Decker Toast R Oven
Выберете то, что вам нужно
  1. How to clean out a Black and Decker Toast R Oven, How to clean out a Black and Decker Toast R Oven: шаг 1, изображение 1 из 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. How to clean out a Black and Decker Toast R Oven: шаг 2, изображение 1 из 2 How to clean out a Black and Decker Toast R Oven: шаг 2, изображение 2 из 2
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. How to clean out a Black and Decker Toast R Oven: шаг 3, изображение 1 из 1
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. How to clean out a Black and Decker Toast R Oven: шаг 4, изображение 1 из 1
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. How to clean out a Black and Decker Toast R Oven: шаг 5, изображение 1 из 1
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. How to clean out a Black and Decker Toast R Oven: шаг 6, изображение 1 из 1
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. How to clean out a Black and Decker Toast R Oven: шаг 7, изображение 1 из 1
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. How to clean out a Black and Decker Toast R Oven: шаг 8, изображение 1 из 1
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. How to clean out a Black and Decker Toast R Oven: шаг 9, изображение 1 из 1
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. How to clean out a Black and Decker Toast R Oven: шаг 10, изображение 1 из 1
    • Finish removing the outside cover by lifting the lid upward.
  11. How to clean out a Black and Decker Toast R Oven: шаг 11, изображение 1 из 1
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. How to clean out a Black and Decker Toast R Oven: шаг 12, изображение 1 из 1
    • Now, you can clean the outside units of the toaster oven.
  13. How to clean out a Black and Decker Toast R Oven: шаг 13, изображение 1 из 1
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Заключение
4 участников успешно повторили данное руководство.
Jonathan
Участник с: 09/18/12
281 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 2-10, Propen Fall 2012 Участник Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 членов
Автор 5 руководств
Один комментарий
This guide is amazing - almost equally because it is so detailed and thorough as because it helped me know exactly how to clean this almost ancient piece of equipment, that's still going strong after what must be 40+ years (in spite of not having been thoroughly, properly cleaned in probably 20!) Acknowledgement to Black & Decker of that era too - let's hear it for American-made products like this one! Thank you for creating this guide!
Lynn - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 75
За всё время: 15,442
