How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip
Выберете то, что вам нужно
  1. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip, Scanner Glass: шаг 1, изображение 1 из 1
    • Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
    • Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
    • Potential for device damage: Take your time prying off the control panel faceplate. If too much pressure is applied, the control panel faceplate can break.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 2, изображение 1 из 1
    • Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
    • To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 3, изображение 1 из 1
    • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
    • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
    • Potential for device damage: Only pull from the connector portion of the cable, as pulling on the wires may damage them.
  4. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 4, изображение 1 из 1
    • Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
    • Using your finger push (pull on some printers) the tab towards the scanner lid. This will release the scanner lid
  5. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 5, изображение 1 из 2 How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 5, изображение 2 из 2
    • Once the scanner lid is removed, use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 6, изображение 1 из 2 How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 6, изображение 2 из 2
    • Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver.
    • Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
  7. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 7, изображение 1 из 1
    • Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip, How to clean the HP PSC 2410 Photosmart All In One Printer callibration strip: шаг 8, изображение 1 из 1
    • Turn the scanner glass over and place it on a clean surface.
    • Moisten a lint-free cloth with alcohol and gently wipe down the calibration strip.
Заключение
8 участников успешно повторили данное руководство.
Jeremy Mahrt
Участник с: 05/08/11
286 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 12-31, Maness Spring 2011 Участник Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 членов
Автор 9 руководств
2 Комментариев
Thank you for this guide! My printer scan head was clicking and grinding at startup and would not allow me to print.
In addition to cleaning the glass and calibration strip, I manually slid the scanner head back and forth through its full range of motion. Once the printer was reassembled, the grinding ceased and all operations are back to normal.
FlyABus - Ответить
Yes, great advice!
And the step by step guide is really of vital help! Just taking the dust flocks out and carefully cleaning the parts w/ a small brush or ear tips and akcohol saved my 12 yr old printer! I'm soooo greatful to you all for helping us keep our hardware goods for a long time to come!
Ambriel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 10,629
