How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass
Выберете то, что вам нужно
  1. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass, Scanner Glass: шаг 1, изображение 1 из 1
    • Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
    • Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
    • Potential for device damage: Take your time prying off the control panel faceplate. If too much pressure is applied, the control panel faceplate can break.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 2, изображение 1 из 1
    • Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
    • To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 3, изображение 1 из 1
    • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
    • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
    • Potential for device damage: Only pull from the connector portion of the cable, as pulling on the wires may damage them.
  4. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 4, изображение 1 из 1
    • Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
    • Using your finger push (pull on some printers) the tab towards the scanner lid. This will release the scanner lid
  5. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 5, изображение 1 из 2 How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 5, изображение 2 из 2
    • Once the scanner lid is removed, use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 6, изображение 1 из 2 How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 6, изображение 2 из 2
    • Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver.
    • Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
  7. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 7, изображение 1 из 1
    • Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass, How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 8, изображение 1 из 1
    • Turn the scanner glass over so its underside is facing upward.
    • Place the scanner glass on a clean surface.
  9. How to clean the HP PSC 2410 Photosmart All In One Printer scanner glass: шаг 9, изображение 1 из 1
    • Moisten a lint-free cloth with alcohol. Wipe down the underside of the scanner glass until all dust is removed.
    WOW, this made the fix super easy………..THANK YOU, THANK YOU
    Dan Troshynski - Ответить
    Wasn’t sure if instructions would fix my 15 + year old printer. I’ll be damned if it didn’t work. Did not have to search too hard to find place to get me back on my feet. Thank you for giving my old all-in-one another chance!!
    Mark Shimp - Ответить
Заключение
16 участников успешно повторили данное руководство.
Hilary Olsen
Участник с: 04/12/11
251 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 12-31, Maness Spring 2011 Участник Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 членов
Автор 9 руководств
8 Комментариев
I thought my printer was a goner for sure, then I stumbled on this site. All I had to do was clean the glass- it looked terrible!- and put it all back together. It was easy. I truly appreciate not having to get another printer- THANKS!
Ben - Ответить
Brilliant! Easy to follow instructions. Printer stoped clicking and works fine now. Thank you!
AL Pierce - Ответить
Great! I followed the instructions already a couple of years ago, and found it now again! Great help! Thank you!
Fritz Abraschek - Ответить
Worked great, but it did take more than 2-3 minutes!
clintsmith - Ответить
This saved me and my printer!! Thx so much! In fact, the dust flocks were just against the internal buses and under the control panel. And I also found out that one can check most of the machine without having to uncable the grey ribbons.
Handle with extreem care though.
Thx thx thx!
Ambriel - Ответить
Oh, and my printer is still going strong after 12 years!! Yay!
Thx, to all of you who contribute here and to all who help us keep the planet cleaner w/ substainable and recycable goods.
Ambriel - Ответить
Thanks for the tutorial, it saved me a lot of time ;-).
Now I’m back on track printing what I need.
Jose De Araujo - Ответить
Thank you so much for the great instructions! I’ve had my printer for over 14 years and it still works great! Just needed to clean the dust under the scanner glass to help get clearer scans of old photos that I am storing on my computer. Hope HP keeps making the ink for this so I can continue to use it for many more years!
maria_scottb - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 14,620
