How to Clean the Panasonic DVD-RV31 Player Laser
Выберете то, что вам нужно
  1. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Tray Cover: шаг 1, изображение 1 из 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. How to Clean the Panasonic DVD-RV31 Player Laser: шаг 2, изображение 1 из 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: шаг 3, изображение 1 из 2 How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: шаг 3, изображение 2 из 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. How to Clean the Panasonic DVD-RV31 Player Laser: шаг 4, изображение 1 из 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: шаг 5, изображение 1 из 2 How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: шаг 5, изображение 2 из 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: шаг 6, изображение 1 из 3 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: шаг 6, изображение 2 из 3 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: шаг 6, изображение 3 из 3
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  7. How to Clean the Panasonic DVD-RV31 Player Laser: шаг 7, изображение 1 из 1
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  8. How to Clean the Panasonic DVD-RV31 Player Laser: шаг 8, изображение 1 из 1
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
  9. How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: шаг 9, изображение 1 из 3 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: шаг 9, изображение 2 из 3 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: шаг 9, изображение 3 из 3
    • Grasp the bridge above the wheel and push the tabs on the side as shown.
    • Pull down firmly and away from the laser housing.
  10. How to Clean the Panasonic DVD-RV31 Player Laser, How to Clean the Panasonic DVD-RV31 Player Laser: шаг 10, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Microfiber Cleaning Cloths
    $3.99
    Купить
    • Be sure to wash your hands before cleaning the optical laser lens.
    • Grab a microfiber or eyeglass cloth and gently brush the lens.
Заключение
4 участников успешно повторили данное руководство.
William
Участник с: 04/26/11
283 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 18-20, Garner Spring 2011 Участник Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 26
За всё время: 7,396
