Введение
If coffee is only coming out of one spout or the knob isn't having any effect on the volume of crema, a cleaning may be in order. This guide will show you how to disassemble, clean and reassemble the spout.
Выберете то, что вам нужно
Remove the spout by pressing the button on top and sliding it towards you.
Unscrew the two PH#1 screws on the back of the spout.
The spout halves should now separate easily but light prying might be necessary.
Remove the spring of the pushbutton. Relaese the Button and remove the black insert off the cup filler.
Push off the metal chrome part.
Clean it with a small brush and rinse it under water.
Reinstall the metal part on the back cup filler part then insert the black piece.
Hold up the black part a little for pushing in the Button.
Then click it trogether and push in the spring.
3 участников успешно повторили данное руководство.
