Введение
The bottom half of the phone will need to be disassembled, see "replacing logic board" for instructions to remove logic board.
Выберете то, что вам нужно
Remove the back panel by pressing up on switch, located at the top on the back of the phone.
Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
Remove the camera and volume buttons and place them in a safe spot until reassembly.
Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
After removing motherboard, the phone will look like this.
By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Еще один человек закончил это руководство.
