How to clean the Sega Genesis game port
Выберете то, что вам нужно
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: шаг 1, изображение 1 из 1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: шаг 2, изображение 1 из 1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: шаг 3, изображение 1 из 1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: шаг 4, изображение 1 из 1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Финишная черта
11 участников успешно повторили данное руководство.
Erik Bjornstrom
Участник с: 10/04/10
829 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 3-29, Regan Fall 2010 Участник Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 членов
Автор 14 руководств
4 Комментариев
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Ответить
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Ответить
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Ответить
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 22
За последние 30 дней: 152
За всё время: 36,042
