Введение
The grille is the part of the microphone that you speak into. Keeping the grille clean ensures that your sound quality is at its best.
Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Put two drops of dish soap into a cup.
Add water to cup until half full.
Place the grille in the solution of soap and water.
Let the grille soak for half an hour.
Remove the grille from the cup and rinse it with cold water.
Allow the grille to air dry.
Make sure the grille and the foam inside it are completely dry before placing it back on the microphone.
5 участников успешно повторили данное руководство.
