How to clean the Shure SM58 XLR connector
Выберете то, что вам нужно
  1. How to clean the Shure SM58 XLR connector, XLR Microphone Connector Disassembly: шаг 1, изображение 1 из 1
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. How to clean the Shure SM58 XLR connector: шаг 2, изображение 1 из 1
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. How to clean the Shure SM58 XLR connector, How to clean the Shure SM58 XLR connector: шаг 3, изображение 1 из 1
    • Using a detailing brush, gently brush the pins and inside walls of the microphone.
  4. How to clean the Shure SM58 XLR connector: шаг 4, изображение 1 из 1
    • Do not solder microphone parts without prior soldering experience.
    • Only attempt this step if you have previously soldered inside the microphone. If the pins on the inside of the connector have excess solder on them, take a soldering iron and melt of excess solder.
  5. How to clean the Shure SM58 XLR connector: шаг 5, изображение 1 из 1
Заключение
To reassemble your device, follow these instructions in reverse order. After cleaning the connector, your microphone is ready to connect to XLR cables.
Еще один человек закончил это руководство.
nat coll
Участник с: 09/27/12
642 Репутация
Автор 14 руководств
Команда
Cal Poly, Team 7-53, Forte Fall 2012 Участник Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 4,111
