Введение
The gearbox tends to get dust and other particles stuck in the gearbox over time as he extruder can grind away some of the plastic filament causing slippage. This is an important general maintenance that any serious user of the printer should consider doing if they are experiencing inconsistent extrusion.
Запчасти
Никакие детали не требуются.
  1. Remove the 3D printed plastic cover by lifting up and to the left. The latches in the back should lift right out, however this can be tricky since the 3D printed connections don’t always sit in place well. Remove the 3D printed plastic cover by lifting up and to the left. The latches in the back should lift right out, however this can be tricky since the 3D printed connections don’t always sit in place well.
    • Remove the 3D printed plastic cover by lifting up and to the left. The latches in the back should lift right out, however this can be tricky since the 3D printed connections don’t always sit in place well.
  2. Disconnect the large colored ribbon cable on the top of the printer by wiggling slightly side to side and pulling up to disconnect. Disconnect the large colored ribbon cable on the top of the printer by wiggling slightly side to side and pulling up to disconnect. Disconnect the large colored ribbon cable on the top of the printer by wiggling slightly side to side and pulling up to disconnect.
    • Disconnect the large colored ribbon cable on the top of the printer by wiggling slightly side to side and pulling up to disconnect.
  3. Set up the printer as you would use it normally by connecting the USB cable from the rear of the printer to your computer and then turning it on. Once connected to your computer bring up the included up software and click 3D print at the top and select Maintenance. Under the new maintenance window, click withdraw. Wait for the printer to beep to indicate it has fully withdrawn the plastic before you remove the remaining end from the extruder assembly.
    • Set up the printer as you would use it normally by connecting the USB cable from the rear of the printer to your computer and then turning it on.
    • Once connected to your computer bring up the included up software and click 3D print at the top and select Maintenance. Under the new maintenance window, click withdraw.
    • Wait for the printer to beep to indicate it has fully withdrawn the plastic before you remove the remaining end from the extruder assembly.
  4. Unscrew the 3mm hex screw, on the underside immediately behind the nozzle heater that holds the entire extrusion assembly in place. Be careful when unscrewing this as there are two small flat washers that can easily fall off. Be mindful that unscrewing this screw will mean that the entire extrusion assembly can come free of the printer body.
    • Unscrew the 3mm hex screw, on the underside immediately behind the nozzle heater that holds the entire extrusion assembly in place.
      • Be careful when unscrewing this as there are two small flat washers that can easily fall off. Be mindful that unscrewing this screw will mean that the entire extrusion assembly can come free of the printer body.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Disconnect the three and four pin connectors on the top of the extruder assembly by gently wiggling the connectors side to side until they become loose and pull out.
    • Disconnect the three and four pin connectors on the top of the extruder assembly by gently wiggling the connectors side to side until they become loose and pull out.
    • These connectors are designed to latch in once in place, so they may be hard to remove.
  7. With the 2.5mm hex tool unscrew the two small hex screws immediately above the top left and right corners of the fan. You do not need to unscrew the fan or unplug the fan connector.
    • With the 2.5mm hex tool unscrew the two small hex screws immediately above the top left and right corners of the fan.
      • You do not need to unscrew the fan or unplug the fan connector.
  8. Once the two screws have been removed the entire plastic body, with fan and connector board, should be able to slide off of the stepper motor by pulling the plastic assembly towards you. Once the two screws have been removed the entire plastic body, with fan and connector board, should be able to slide off of the stepper motor by pulling the plastic assembly towards you.
    • Once the two screws have been removed the entire plastic body, with fan and connector board, should be able to slide off of the stepper motor by pulling the plastic assembly towards you.
  9. Remove the small white plastic gearbox at the base of the stepper motor. Check for any ground down gear teeth or signs of excessive wear.
    • Remove the small white plastic gearbox at the base of the stepper motor.
    • Check for any ground down gear teeth or signs of excessive wear.
  10. Clean the stepper motor gear by brushing it with a fine stiff brush and ensure that all of the plastic remnants and dust have been removed. If needed, use q-tips dipped in rubbing alcohol (higher percentage the better) to swab out the remaining particles left over.
    • Clean the stepper motor gear by brushing it with a fine stiff brush and ensure that all of the plastic remnants and dust have been removed.
      • If needed, use q-tips dipped in rubbing alcohol (higher percentage the better) to swab out the remaining particles left over.
  11. This picture shows all the tools and parts in the guide.
    • This picture shows all the tools and parts in the guide.
    • Replace the gearbox in the same orientation as before in the previous step.
      • The gearbox should make an audible “snap” as you fit it into place.
    • Repeat the steps backwards to reassemble the module.
Заключение
3 участников успешно повторили данное руководство.
Brian Greenberg
Участник с: 08.10.2014
145 Репутация
1 Guide authored
Команда
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 9
За всё время: 1,070
