How to clean your Panasonic SA-HT810V VCR heads
Выберете то, что вам нужно
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: шаг 1, изображение 1 из 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: шаг 1, изображение 2 из 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: шаг 1, изображение 3 из 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: шаг 2, изображение 1 из 2 How to clean your Panasonic SA-HT810V VCR heads: шаг 2, изображение 2 из 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: шаг 3, изображение 1 из 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: шаг 4, изображение 1 из 3 How to clean your Panasonic SA-HT810V VCR heads: шаг 4, изображение 2 из 3 How to clean your Panasonic SA-HT810V VCR heads: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Microfiber Cleaning Cloths
    $3.99
    Купить
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
Заключение
2 участников успешно повторили данное руководство.
Nathan Cheadle
Участник с: 04/15/10
161 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 16-5, Maness Spring 2010 Участник Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 23
За всё время: 2,688
