Введение
This guide can teach you how to repair/remove a paper jam for the Epson Stylus Photo 820. No tools are necessary for this operation, and no working knowledge of the printer is needed.
If a paper jam is detected, the middle button will display a red light.
Press the red button. This will cause the printer to try to automatically correct the issue.
If this works, proceed to step 4. Otherwise, proceed to step 2.
The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
Pull the paper slowly, and as straight as possible.
If this does not work, proceed to step 3.
Assuming the paper will not come out of the top, assess the paper jam.
If the print cartridge is in the way, gently push it to the side.
Try to get the full edge of the paper above the metal grating.
Gently pull the paper out the of the open hatch.
If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
If steps 2 or 3 corrected the problem, you will need to press the red button again.
This may cause another sheet of paper to be pulled through. Do not be alarmed.
This should cause the red light to go out.
Еще один человек закончил это руководство.
