How to clone a Hard Drive or a Solid State Drive on a Mac
Выберете то, что вам нужно
  1. How to clone a Hard Drive or a Solid State Drive on a Mac, Downloading Carbon Copy Cloner: шаг 1, изображение 1 из 1
    • Download Carbon Copy Cloner from the Bombich Software Website.
    • Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
    • You can download it here.
    • I used CCC 5 for this process and if the user interface changes in the future I will promptly update the guide.
    Спросите у FixBot
    Добавить комментарий
  2. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Source Disk: шаг 2, изображение 1 из 1
    • Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
    • Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
    Спросите у FixBot
  3. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Target Disk: шаг 3, изображение 1 из 1
    • Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
    Спросите у FixBot
  4. How to clone a Hard Drive or a Solid State Drive on a Mac, Cloning: шаг 4, изображение 1 из 1
    • Lastly, click Clone.
    • Enter your administrator Username
    • Enter your administrator Password
    • Then finally, click OK
    • This process can take up to 4+ hours depending on your disk size, so have some patience!
    Спросите у FixBot
Заключение
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
29 человек успешно провели ремонт по этому руководству.
[deleted]
Участник с: 08/28/18
27 902 Репутация
Автор 21 руководств
10 Комментарии к руководству
I have used CCC for years and years. It is an excellent program!
When upgrading MAC OS to a new version, I always clone a drive before starting the upgrade.
Mal - Ответить Поделиться
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
Fran Werttt - Ответить Поделиться
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan - Ответить Поделиться
I have tried cloning my 2012 Mac book pro with a vector ssd sata111, my Mac does not see the disk when I connect with usb or caddy, this is getting frustrating anyone has the same problem where you mac not seeing the ssd drive
thank you
Peter
Peter - Ответить Поделиться
What about using Restore on Disk Utility read on web that this in itself a cloning method don’t have to go for 3rd party apps
GBish - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 85
За последние 30 дней: 466
За всё время: 61,602
