How to convert your Mac's storage from HFS to APFS file system
    • As a preventative measure, it is highly recommended you create an external backup drive to backup your files to
    • Typically converting your file system should not effect your data, but there is always a risk of loosing data when messing with the internal drive.
    Спросите у FixBot
    Добавить комментарий
  1. How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: шаг 2, изображение 1 из 2 How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: шаг 2, изображение 2 из 2
    • Open the Disk Utility application and click the View option in the left hand corner.
    • From the drop down menu, choose the Show All Devices option from the list.
    Спросите у FixBot
  2. How to convert your Mac's storage from HFS to APFS file system, Select the drive you want to convert: шаг 3, изображение 1 из 1
    • You should see a list of all your containing drives within each of their respective volume. Select the drive you want to convert and click the Partition button from the buttons in the upper right hand side of the window.
    Спросите у FixBot
    • Make sure your Scheme is set to GUID Partition Map
    • Depending on the drive you're converting, your Scheme may be set to the "MS-DOS" format. In this case you would need to change the partition format.
    Спросите у FixBot
    • Select Mac OS Extended (Journaled) from the "Format" dropdown menu.
    • Make sure the settings are correct, and click the Apply button.
    Спросите у FixBot
    • Right click on the partition you set, and select Convert to APFS.
    Спросите у FixBot
Заключение
Congratulations! You have successfully converted your drive to APFS. As stated previously, your files should have not been touched, always make sure everything is correct.
4 человек успешно провели ремонт по этому руководству.
Jacob Mehnert
Участник с: 10/18/21
49 076 Репутация
Автор 51 руководств
Команда
iFanatics Участник iFanatics
Community
69 членов
Автор 237 руководств
1 Комментарий к руководству
Above, it says under “Cons of APFS” that it “Does not support Fusion drives.” This is incorrect. My 2019 iMac runs Sonoma and has automatically converted my Fusion drive to APFS, dramatically slowing down the system. Don’t convert or permit APFS file systems on mechanical or “fusion” (hybrid) type hard drives, unless you really want to torture yourself and your Mac!
reeskm - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 215
За последние 30 дней: 447
За всё время: 29,390
