Введение
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
  1. Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take something sharp and make hole where the chip was.
  2. Use a pair of scissors and cut the card into thin strips.
    • Use a pair of scissors and cut the card into thin strips.
    • See the photo.
    • It is not recommended to have the strips thicker then 2mm.
    • The distance you see in the blue circle is not recommended to be more then 2mm.
    • Cut the card into many small parts as seen on the photo.
    • It is recommended to have a box/tin to prevent the parts to fly anywhere.
    • Look on the floor and on the table and see if you lost some parts of the card
    • If you found some, cut them also.
    • See previous steps.
    • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
    • Recomanded min 2 places
      • Taking it to the neighbor will not increase security a lot.
Финишная черта
24 участников успешно повторили данное руководство.
Комментариев: 7
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - Ответить
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - Ответить
Please correct some typo but yes you got the
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Rabitts take the hard drive and burnt it to a crispy ashes.
Просмотр статистики:
За 24 часа: 3
За 7 дней: 28
За 30 дней: 128
За всё время: 9,407
