How to determine Mac shutdown causes
  1. How to determine Mac shutdown causes, Open Terminal.app: шаг 1, изображение 1 из 1
    • Open Terminal.app
    Спросите у FixBot
    Добавить комментарий
  2. How to determine Mac shutdown causes, Listing previous shutdowns: шаг 2, изображение 1 из 1
    • Copy and paste the following command in your Terminal window:
    • log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
    • The "24h" portion of the command can be changed to any number of hours, depending on how far back you need to see.
    Спросите у FixBot
  3. How to determine Mac shutdown causes, Determining Shutdown Causes: шаг 3, изображение 1 из 1
    • The previous shutdown causes in the timeframe you selected will appear as a list.
    • Common shutdown causes include 5 which indicates a normal shutdown, 3 which indicates a hard shutdown (i.e. holding the power button), and 0 which indicates the power was disconnected.
    • A list of shutdown causes can be found here: Shutdown causes (from George Garside blog)
    Спросите у FixBot
Заключение
Done! You should be able to use these codes to further troubleshoot random shutdowns or other strange events.
Hit the button below if this guide helped solve your issue :)
24 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
Jonah Aragon
Участник с: 08/05/18
5 716 Репутация
Автор 5 руководств
Команда
Experimax Coon Rapids Участник Experimax Coon Rapids
Business
3 членов
Автор 19 руководств
14 Комментарии к руководству
For me it says
kernel: (AppleSMC) Previous shutdown cause: -20
The attached PDF (and the internet) doesn’t seem to have any information about this code. What’s the source of the codes for the PDF? Maybe they have updated listing for shutdown codes.
Saurabh Shrivastava - Ответить Поделиться
we also have -20 as a cause and have no idea what it means. did you ever find it out?
octomobiki - Ответить Поделиться
I also have -20 code of shut down after macOS 10.15.5 update with MBP 16inches model.
but no information at all….
赤月小黄泉 - Ответить Поделиться
writErr = -20, /*I/O System Errors*/ its this error for code -20 .. Find all error codes here :- https://krypted.com/lists/comprehensive-...
UNKNOWN X - Ответить Поделиться
Sorry , that was not related, check this one : - https://georgegarside.com/blog/macos/shu...
and, error code 20- T2 security chip initiated shutdown
Статистика просмотров:
За последние 24 часов: 19
За последние 7 дней: 108
За последние 30 дней: 472
За всё время: 107,392
