Введение
The Apple Carplay system in a car (specifically a 2016 Honda Accord in this case) can sometimes malfunctions and cause a few minor technical difficulties. In order to both address and fix these technical difficulties, it is often quite useful to reset the vehicle’s system and make sure the charging connection is secure.
Apple CarPlay can sometimes stop working for a variety of reasons but the main reasons are often USB-charging port connection and iPhone update related. We hope to address both of this issues with this guide.
Our guide will outline these steps and show you how to get your Apple Carplay system back up and running in absolutely no time!
Выберете то, что вам нужно
Disconnect your phone's USB cable from the USB port and the Apple Car Play system.
Update your phone’s operating system and restart your phone. Make sure your phone is updated to the most recent version of IOS, Android, etc. to ensure your phone is fully able to run the Apple CarPlay app.
Clean out the phone’s charging port using WD-40 Electrical Contact Cleaner Spray or a similar product. Wait a few minutes to allow the charging port to dry off before reinserting the charging cable back into the charging port.
Replace the charging cable in vehicle. Make sure the charging port is completely dry and remove all dirt, dust, grime, and debris.
Navigate through your Honda's dashboard settings and pull up the System Settings. Continue to navigate until you find a setting for "Factory Reset"
Once the Factory Reset prompt appears on your screen, select yes and wait a few minutes for your system to reset and return to default settings.
Once the Dashboard interface system has completed its' Factory Reset, turn of your Honda Accord and wait a few minutes to restart your vehicle.
Once restarted, your Apple CarPlay system should be completely functional again.
Еще один человек закончил это руководство.
